I was looking at that. It would be great to have a control lever on the left side as well.Look at the pic of the start/stop handle linkage across the front of the table. One pic shows the stop setup. You would have to move the DRO X axis reader to the rear of the table to set the stop system up as original. I ran the mill in the pic for about 15 years........never had the clutch ever kick out.
I just pulled the handle and bracket off of the right side. It looks like i will have to pull the lead screw and turn it down to .625 and make an extension to screw onto the end to make it a bit longer. Or, I could just cut the entire end off and make a coupling and attach an entirnew end that will fit the power feed.
Like this. Those are roll pins.
And, thanks Akuia! I know I do!
