Could Someone ID This Bridgeport Power Feed For Me?
Look at the pic of the start/stop handle linkage across the front of the table. One pic shows the stop setup. You would have to move the DRO X axis reader to the rear of the table to set the stop system up as original. I ran the mill in the pic for about 15 years........never had the clutch ever kick out.
I was looking at that. It would be great to have a control lever on the left side as well.
I just pulled the handle and bracket off of the right side. It looks like i will have to pull the lead screw and turn it down to .625 and make an extension to screw onto the end to make it a bit longer. Or, I could just cut the entire end off and make a coupling and attach an entirnew end that will fit the power feed.
Like this. Those are roll pins.
And, thanks Akuia! I know I do!
Nice! I like old Italian machinery. A small VFD would run that and give you all kinds of variable speed goodness- or a simple static converter would serve
Your Bridgie looks like new also- congrats
-Mark
Two more..
This is my next move. I have to cut the lead screw and make a new shaft to attach to it. The unthreaded part that will be cut is 1" dia. That should be large enough to just drill and ream a .625 hole into the cut end and have a simple joint with only 1 roll pin.
If anyone thinks that I could do this a better way, then by all means.
Thanks to everyone for your input and efforts helping me on this!
I got the end that was cut, bored out to accept the longer shaft. I gave it a good cleaning when I was done. It had been getting greased.
All finished and ready to go back on the saddle.
Just have to take it all apart again.
The hub for the dial had to be trimmed on the backside. A .005 feeler gauge wont slip in and the dial doesn't rub the pf housing. Much of what I did was outlined in a fied installation guide that I found. If a BP tech showed up to your shop in 1970 to install this, he would have had a new lead screw with him. 16160394337973494594358641446021.jpg
Thank you! This should be running today! I had my son help me put the table back on before he left kast night.
