- Jan 4, 2021
- 912
That's also an option.For a 7/16-10 I would be concerned about the clearance on the laydown insert. I would probably grind a HSS tool for that pitch.
I think I'd rather have the clearance at the tail stock. For what I am doing, I will probably put a live center in the end of the piece. It'll be 2-5/16" of thread of a 3" piece.The insert cutting tip will cut equally on either side. Your existing RH insert and tool holder will cut up closer to a shoulder at the chuck than a LH insert and tool holder, by the width of the holder. If you can live with that clearance, both at the chuck and tailstock, then you are good to go.
Right handed tools will only cut properly on the leading edge as there is no clearance on the trailing edge. Cutting away from the chuck on the trailing edge may not have sufficient clearance. Right handed boring bars will cut left handed external threads. Unfortunately threaded spindles do not like reverse but a slow speed and a shallow cut should pose no problems if it is fully tightened and not reliant on cutting pressure to tighten the chuck.I should have provided some additional detail, not that it necessarily changes anything.
I have a threaded chuck, so I won't be running the lathe spindle clockwise, it'll always be counter clockwise facing the chuck. Which necessitates running the carriage away from the chuck for me. And I have my tool in front of the chuck. So it would seem this would be my setup.
I currently have a right hand tool holder and some 16ER AG60 inserts which is similar to what is pictured. would have thought that I would want a LH tool holder and possibly would use the 16IR AG60 insert that came with my internal threading tool, but I have no idea if the geometry of the insert would be correct in that situation. I also would have thought that the tool pressures would be vastly different using a RH tool cutting away from the chuck and I could break an insert a lot easier. Plus I think the shim would be in the way. Is that what "Change to Negative Anvil" means? Replace the shim?
Here is my threading tool I have now.
I'll also note, I am not making parts for Space-X. Just some missing parts on the South Bend steady rest I have.
I wish I understood most of what you are trying to convey. Believe me, I do appreciate the information. I am trying to soak up as much as I can. I'll learn this eventually the more I get into this arena.My concern was this: A 10 pitch thread on a 7/16" diameter will give a pretty large lead angle (helix angle). The lead angle should be calculated based on the minor diameter of the thread. Does the clearance angle of the insert exceed the lead angle? I know Carmex and other high end threading systems use shims to adjust for differing lead angles but I suspect most hobby machinists have tool holders with a fixed seat angle.
The test by mylilmule was with a HSS tool not an insert.You just proved the insert had adequate clearance to cut 7/16-10. You did it by trying it. I would have used math. Same result.
