- Feb 8, 2014
- 11,144
It's very possible.
Measure hole edge to hole edge then add the hole diameter, that gives the center to center distance. Part edge to hole edge plus 1/2 the hole diameter gives the center distance from the part edge. Add that to the center to center distance and that gives you the location of the second hole from the part edge.
This works as long as all of the hole diameters are the same. If the holes are different diameters, you do the same thing but add half the diameter of each hole to get the center to center distance.
You already have a 3D model, just move and size the holes in the drawing to match the actual measurements of the part that you want to copy.
