Converted boring bar to Ball end turner
Just for fun
Tim Young
H-M Lifetime Diamond Member
Oct 7, 2020
2,116
I made a couple parts to convert my boring bar to a ball end turner. Here is the finished product. I purchased a 3/4" straight shaft arbor for the boring bar. I made the handle end cap so when it is tight there is just the slightest amount of drag.
I turned a piece for the cutter, 12mm one on end for the boring bar and 6mm for the for the RCMT 0602 cutters.
I'm planning on adding a handle, but it worked pretty well with just an Allen wrench in the end.
I did turn a little ball end just for kicks and grins.
Added a magnet and put it to use.
It's not finished yet, but it's all I got for now.
Thanks for looking.
Tim
A nice addition would be adjustable stops, as I did, but you would have to make the pivot shaft longer to accommodate the clamp on stops.
I finished up my ball turner project.
I always thought this would be cool, turning the head of the mill. It worked but kind of a PITA for one hole.
After I drilled and tapped the hole, I took a 7/16 end mill and bored it out a bit to hide the threads.
Doing a test fit on the handle and ball end.
And there it is, I was going to blacken the part that the handle screws into but decided I like it the way it is.
