    Dismiss Notice
Cleaning oil lines
Discussion in 'MACHINE RESTORATION & WAY SCRAPING' started by Ropata, Jul 9, 2017.
  1. Ropata
    Ropata New Zealand Active Member Active Member
    4
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    Can anyone tell me the best way to clean out oil lines on my mill restoration? [​IMG][​IMG]
    Sent from my SM-N920P using Tapatalk
  2. dlane
    dlane Active User H-M Supporter-Premium
    675
    113
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    Search using tapatalk, pics are red x
  3. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,715
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    Here are the red X pictures from above:
    G'Day,
    i have heard that acetone works, but i have not tried to verify.
    i would say that diesel fuel or mineral spirits would also suffice, i have used those 2 fluids
    best of luck!
    mike
    itsme_Bernie likes this.
  4. Ropata
    4
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    Yeah they show up for me. I'll look into it when I'm home from work. Cheers.
  5. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,088
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Best thing to do is put fresh oil like a ISO 46 oil in the one shot reservoir and start pumping oil until you see fresh oil come out at the oiling points. That means, the oil turn from a very dark color to near clear fluid like. Do this until all oiling points show clean oil. Once that's done, fill the reservoir with your flavor of way oil. It means a lot of oil waste, but is the easiest way doing so. That way, if you encounter a oil line that does not deliver oil, pull that line and replace. It is difficult to get a oil line unclogged sometimes. I have a air nozzle fitted with a fitting that adapts over to the Bijur oil line fittings. What I'll do is connect the oil line to the air nozzle and attempt to use compressed air to unclog. Just be sure to point the oil line away from you when you shoot the air to it! If nothing comes out of it, don't look at the muzzle end of the oil line. It could come out and blow your eyeball out and if the oil was to get in your blood stream, kill you. So be careful! If there are metering units, that regulate the flow of oil, in line and that's where the oil flow stops, remove and replace the metering unit. They are a hit and miss trying to clean and get them to flow oil thru once they are clogged up.
    Ropata likes this.
  6. British Steel
    British Steel United Kingdom Active User Active Member
    353
    83
    City:
    Camberley
    -Return to Top-
    I've found that if the pipe's bends aren't too tight, a wire-wound guitar string can be quite persuasive...
    Dave H. (the other one)
    Fitter Bill, tertiaryjim and 4gsr like this.
  7. tq60
    tq60 United States Active Member Active Member
    173
    43
    City:
    madera
    State:
    California
    -Return to Top-
    Also try ATF as it is thinner and very high detergent so it will clean better.
    It also shows better being red.
    4gsr likes this.
  8. Silverbullet
    Silverbullet Active Member Active Member
    689
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    Are the lines metal or plastic. I'd put some carb cleaner thru them or starting fluid either. Plastic I wouldn't use it tho. Acetone pumped thru even.
  9. Ropata
    4
    8
    City:
    Wellington
    State:
    Outside US / Canada
    -Return to Top-
    Aluminium. Yeah I might fill the pump with a solvent and pump that through.
    4gsr likes this.
  10. Old junk
    Old junk United States Active Member Active Member
    35
    18
    City:
    Hackettstown
    State:
    New Jersey
    -Return to Top-
    Diesel or kero works for me,which ever jug is closer
  11. Dabbler
    Dabbler H-M Supporter - Premium Content H-M Supporter-Premium
    90
    28
    City:
    Calgary
    State:
    Alberta
    -Return to Top-
    On my Surface Grinder repair, I used .035 MIG wire, which just fit my plastic tubes. No amount of thinner would clean them, so mechanical was the only way I could get the crud out...
    4gsr likes this.
Share This Page
