- Apr 14, 2014
- 3,169
I have nearly 100 die files I inherited from my father-in-law over 25 years ago. I never paid much attention to them but do use a few on occasion. Today I needed one, so I pulled out the boxes to find most were covered in grease, grime, and oil from years of use in a commercial shop. I cleaned the couple I needed with a file card and was amazed at how sharp they still were.
That got me to thinking it might be time to clean the whole batch. I don't really relish sitting at the bench for hours on end scrubbing with a file card. Many of them have teeth so fine the card is of little use. Others are so thin and small I doubt they could withstand a scrubbing without breaking. There are literally dozens of profiles, and some specially ground to fit in tight places.
Has anyone found a less labor-intensive method for clean the years of crud off these fairly fragile files? I was hoping there was some cleaning fluid on the market that I could soak them in to get the bulk of the crud off. Then rubbing them with a fine file card or soft brass brush. Any input would be appreciated.
