- Sep 28, 2013
- 4,319
nice!
This drill press has a Jacobs 14N Superchuck. It did not come with a key so I looked online and found that it uses a Jacobs K3 key. This key does not seem to fit the chuck very well. The diameter of the gear teeth on the key do not fully engage the teeth on the chuck. Do I have the correct key? What am I missing?
Robert
Interesting thought. Could the outer sleeve be pressed on in the wrong place so the distance to the gear teeth is too great?
Robert
It just doesn't seem like the teeth are fully engaged to me. The key tries to torque away when you tighten it:
The sleeve seems to be pressed on correctly?
Can the sleeve be moved closer (further down)? Does the sleeve have a boss or lip that stops its travel when pressing? I have never disassembled a drill chuck.
Robert
