- Mar 25, 2013
- 4,621
I just got this sewing machine motor in the mail today:
In spite of its small size it is rated at 1HP and goes up to 4000 RPM. I plan to replace the drill press motor with this and have the added advantage of full speed control. I hope the torque will be adequate. I plan to use the pulleys to get about a 2:1 speed reduction.
This motor comes with a max speed setting on the control box as well as a variable speed foot pedal. Here is the pedal control:
As you can see, it uses a magnet that sweeps over a Hall effect sensor. I am not versed in the operation of these sensors. I would like to convert this to a simple ON/OFF switch that starts the motor at maximum speed. Can anyone help me bypass the Hall sensor to achieve this? There are 3 wires coming from the circuit board. I assume red is V+, black is Ground and Yellow is Signal? Can I simply connect yellow to V+ and get a full speed input?
Any other comments welcome.
Robert
Robert
