No, I brought it home in 3 pieces, head, base, and column/table.
I am stripping it down. I figure if I take it apart I will understand the machine know what needs fixing, so when I put it to work, I know it's square, tight, and wet. I already found the bearings in the idler are probably gone. most of the machine looks very , very good. Also the machine stinks , so this is a good time to clean it up, and get rid of that smell. After all it's not in a shop, it's in my basement. The wife insisted the base was not coming in with all the rust, so that was handled yesterday out in the garage. A full wire and sanding with a grinder. I'm going to have to make levelers for it, and at the same time raise it up.. I was surprised how low it is.
Currently the base, base cabinet, and extender are getting stripped. Needs a second coat, this time with a 55gallon garbage bag over it. Many Clausing really used a lot of filler on the base which is why there were so many divets. I don't plan on filling, just paint, figure once pieces land on it, it wont' take big chunks. Man the horizontal (RAM) not sure what to call the slider weighed a ton. Holly crap.. that was tough getting it into my little SB 9a...
BTW if you look at my albums, you'll see how far I took the SB 9a... All the WAY!!! It's a great way to know a machine. That was 2 months of work morning, and night.
