Thanks. I guess I could just use some all thread then.any metal will do. Mild steel, SS, even alum, the purpose of the draw bar is to pull it and hold it in the taper. The taper does the work, the draw bar just prevents it from moving out.
I might suggest a 1035, 1044/45 or something specific for bolt manufacturing an A182 or A193.What metal is a 8520 drawbar made out of? I bought a new drawbar (way overpriced) from Clausing and it sucks. I give up and I'm just going to make a new one. I figure I'll just turn one on the lathe and cut the threads.
I would not use all thread, Use something that fits in the bore (self centers), that way you don't have to find the female threads, the draw bar will find it for you.Thanks. I guess I could just use some all thread then.
