- Aug 29, 2019
- 510
Looking forward to seeing the pictureSeems crazy that an image doesn't exist. I will definitely be taking a picture and posting it when I see the lathe on Friday.
I may call them today and see what info they have.I wonder if you'd have some luck by getting in touch with Clausing directly? I know with the Atlas stuff, especially shop drawings, they still have a lot of them on file in their archive and are quite happy to send PDF's if the part itself is no longer available. Be worth a try -- I'm guessing if they did have a copy it'd be pretty clean!
Here's the lathe I'm looking at on Friday.
As you can see the metal plaque is there. I'm just a bit worried that it will be unreadable.
If it isn't though I will definitely post a pic.
You read my mind!It if has the plate, those are usually etched brass, so even if the paint is worn badly you can still kind of read them. If really worn the old lay a piece of paper against it and run the flat of a pencil over the paper can bring out illegible writing on these kinds of things too.
Thanks Frank!Bravo!
