- Oct 16, 2019
- 6,576
On Friday I'm looking at a Clausing 100 Mk3 without the QCGB. The seller says there are some change gears. I see from the manual that the full count is 12 gears. What I can't find is an image of the gear chart off the change gear cover so that I can see which gears are required to the threads I'd typically cut.
If someone has a shot of the gear chart I'd be mighty grateful.
Here's a shot of the lathe.
