Hi all, I need to clamp an 8mm x 250mm square piece of cast aluminium plate to machine a small number of 3mm holes with 6mm counterbores.
The already machined surface of piece needs to be protected at all costs as it will become the print bed of a fairly high end (in home user standards) 3d printer.
I only have the common milling machine hold down clamps that are sold everywhere and not much else, so was wondering what the advice was to securely hold the workpiece without marking the surface or distorting the piece in any way.
I know my usual "tighten the clamps down with the force of a thousand sun's" is out, so was thinking of raising the whole thing off the table with 1x2x3 blocks to get the clearance to drill the through holes and place a piece of Alu beer can shim over the blocks, then use a few bits of sacrifical aluminium plate under the step clamps to spread the force out, does that sound reasonable?
