- Nov 28, 2021
- 23
I just spent 2 hours again trying to figure out the gear setup to put the lathe (101.07301) back the way it was after cutting some 20 tpi screws as an experiment. I have had the lathe for over 20 years, and always wanted to see how to cut threads. I never want to go through that again. Either I'm missing a gear or spacer or something, but the configuration doesn't jive with either the chart on the lathe, or the chart and description I have in the Thread Cutting booklet.
I'm thinking that when I need to cut threads on something again, I may not attempt it again because it's so difficult to figure it out.
Is there another lathe, not too big, that allows you to change gears without actually pulling them out and changing them. I've seen pictures of lathes with levers to select different gears. Is there a lathe like that that's not super expensive or large? I'm open to buying one.
