- Aug 26, 2013
- 1,061
for the shapes any of these should work.
SC*N or SC*R where * is literally any letter since its the tolerance. I would recommend C, G, H, or K as they are tighter tolerances.
Numbers wise you want 42* in ANSI nomenclature, & 1203** in ISO nomenclature. * is the tip radius and bigger is better. in ANSI, 2 & 3 where common, in ISO it would be 08 & 12.
For the chip-breaker & grade/coating you will need to look it up once you find the right size and shape insert, because their is no standard, and each manufacturer has it's own naming scheme.
