- Feb 2, 2013
- 3,627
i make a habit of applying center lube each time i am going to use the center- whether i'm first setting up or reinstalling after measurement
make sure you don't over tighten the center- it will create a lot of heat and can ruin the work or center or both .
oil will lube but it may be squeezed out of the center-work interface.
ep grease has shear resistance that oil cannot match- making the ep a better choice, if available.
a dead center can produce very accurate work , but there are concessions to working with them
