- May 16, 2016
- 1,702
Prussian blue might also be known as bearing blue. but in a pinch I imagine lipstick might work, any colour as long as its a solid colour. I have even seen very black moly grease used in a pinch.
There is absolutely no doubt in my mind that you meant anything by it,but thanks for the compliment. Let's get back to making chips. No as far as I know the nose is ok,but I thought it could have been a factor for runout. I have a lot going on tomorrow, but now I want to check the taper if there is any runout. I will let you know.Oops, when I mentioned an inexperienced person I was being hypothetical. But I can see that my post can read like a prejudice towards you and I apologize for that. Your reply is perfectly acceptable and your diplomacy is outstanding.
Along the lines that this is your spindle and you are considering grinding the nose taper may I ask what problem the taper is causing?
Hi Tozguy. The runout on the nose is only 0.000787. So the problem lies somewhere on the chuck or backplate I think.Oops, when I mentioned an inexperienced person I was being hypothetical. But I can see that my post can read like a prejudice towards you and I apologize for that. Your reply is perfectly acceptable and your diplomacy is outstanding.
