- Apr 8, 2021
- 73
It's indexing with a 40:1 or 60:1 worm gear, you are doing unecessary thinking
the easy is to buy a saw blade for vinyl siding 120 teeth that look like this vvvvv with a spring loaded indexer. no work with measuring or drilling. all it it needs is teeth counting and labelingId like to make a smal precision index that I can use to divide not only common gears, but pretty much any radius I really want. Its for dial indicators and eventually watches, so I'm not going to be sweating over primes, but I have this little itch after doing some quick memopad math, that I should be able to hit just about every degree or whatever up to a reasonably usable number with a minimal amount of drilled rings.
The 1./12 and 1/15 divisions should take care of all the smaller number sets, and then by having a larger clever ring or two, as well as an "offset" to slide between the 30 or 50 pin wheels, I feel like there is a way to make a maximum amount of gear patterns with a minimum number of holes.
I worry that this is actually getting into some pretty heavy theoretical maths, I have no Idea if anyone has figured this out before, and I don't know where I'd look to find papers on the subject anyways.
Its just a neat thought experiment. How can I make the maximum amount of variations with the smallest amount of hole sets. The answer lies in being able to offest the rings by fixed amounts to use them for more than one position. I jsut like thinking about this stuff, and its way cooler than spening a week CAREFULLY marking with dividers, drilling 500 holes, then reaming each one perfectly, only to slip up 90% percent of the way through and contemplate baking my head in the oven. (not serious)
EDIT: my dying stiff miserable keyboard is unreliable so I apologize for the constant egregious typos
EDIT NUMERO DOS; I mistyped radius a bunch as radians. screw radians. I aint got time for that **** and its not applicable to this in any way any how. RADIUS not RADIAN
An additional solution worth looking at is one of the pre-made indexing plates from Alisam Engineering. They're designed to jam between the lathe spindle and chuck of a woodturning lathe. Pretty easy to adapt to a metal lathe - just enlarge the hole as needed, maybe mount to the outboard end of the spindle. They have one ring of 72 holes and another of 20. This will cover a wide range of divisions.
Alisam Engineering Universal Indexing Systems
Model WIS-1.0 and WIS-.75 Complete universal system for indexing on most 7 to 12 inch wood lathesalisam.com
Thanks for the excel spread sheet! Is that able to be edited?You can also use the BS0 calculator I created for Excel.
You can easily modify it to suit Your dividing head.
