- Apr 30, 2015
- 11,327
Is there still a separate pump switch on the panel? I'm wondering if the pump is set up to run whenever the lathe motor is running?
Yep. Its a Mill but same theory.Is there still a separate pump switch on the panel? I'm wondering if the pump is set up to run whenever the lathe motor is running?
Understood. I will go back and trace the cabling again, I thought that this was in the power feed to the coolant pump not the motor but now i'm doubting myself...The arrowed bit looks like the reversing switch shown in the schematic above the contactor.
It looks as though it had been broken off and remounted
