- Nov 28, 2016
- 2,351
This is not (entirely) true. They have a very slightly differing spec with regard to headspace, which is usually over-emphasized in the literature. Their pressure difference is largely irrelevant (and for the most part everything loaded for one, works for the other). The same is true of .308 and 7.62 Nato. In theory a .308 minimum chamber *could* have a throat shallow enough that a 7.62 round would be constricted at the neck and generate excessive pressure. In practice, every .223 chamber I've seen is throated so deeply that either round can be fired with impunity. Those desiring extra confidence in a chamber to fire both can use the .223 Wylde. I can attest that this chambering has negligible deleterious effect on accuracy. My Wylde chambered competition gun shoots sub-0.75" off the bench and could probably do better if I wished to make the trigger more bench friendly.
GsT
I prefer the .222... can't be fired in either one, but is generally more accurate than .223 or 5.56...
Just stirring the pot... lol!
-Bear
