Cad/cam Problem
I think you're right, sounds like a Mach3 issue. I don't have an answer for you.
Thanks for your help Jim. I'll load version 062 and see if that solves the problem.
Tom S.
I would start by getting a different version of mach3
.066 is junk so no matter what you should start there.
I'm using Version R3.043.057 without issue. the latter versions of mach3
were trying to fix lathe and the more they worked on lathe the worse mill got.
before installing an older version, make copies of your .xml files
after installing the earlier version, copy the .xml files you saved back into mach3 and you
will not have lost your settings.
uc100 may or may not have to be reinstalled, I can't remember
link to previous versions :
ftp://machsupport.com/Mach3/
Steve
I'll give it a try. Thanks.
Tom S.
Here you go. I couldn't upload the dxf file so I changed the extension to txt. You should be able to change it back to dxf and load it.
Tom S.
Unfortunately that did not work.
I ran your code last night on a scrap of MDF but without dimensions I cant say if the center circle is correctly placed in the X axis. It is round and centered in the Y axis. The measurements I get (roughly) are 0.55" between the flat outer edge and the circle edge and 0.6" from the radius outer edge to the circle edge. The circle is 1.73".
I imported the dxf file in to my software and centered it in the work piece. The outside profile is centered but the center hole in off in X by -0.0321
These are the measurements returned by my software as I have seen issues with importing dxf files in the past I will post them here.
X 2.7002"
Y 3.156
Center diameter 2.01
If you wanted the center vector in the center of the piece than there is your problem if not then never mind.
Ray
Is this what your part looks like? I get 0.0642 arc center offset (outside arc center to hole center), the hole center is offset to the left from the arc center. I wonder if the CAM program is picking up the wrong center?
Yes, this is the same as my drawing. Below is a screen shot of my fixture. I use an indicator to locate the spindle central to the spigot, e.g. X = 0 and Y = 0. I then clamp my part to the fixture then machine the profile. Next I chamfer the periphery then the bore. All operations are based on the original X and Y reference. Could be my CAM program is picking up the both center points but I don't know why.
Tom S.
X 2.7002"
Y 3.156
Ray
This could be the problem. I need to look at my drawing again. This could all be related to the way I built the drawing.
Tom S.
Jay - The drawing that Jim posted is correct. Thanks for looking.
Tom S.
I figured out the tool size and the rest of the parameters from the G-code you posted.
Attached is G-code from your DXF and my CAM program, using a Mach3 post processor. Give it a try, but make an air cut before you try to make chips just to make sure it behaves.;)
  • Roll Bar Clamp Periphery Machining Drawing MACH3 POST.txt
Will do.
