- Aug 6, 2015
- 3,892
We have different VFDs...I have the Telco L510, but the parameter that helped mine completely quiet down was the last one on this list... Can you check yours and see if it has something similar?
Control Method -> Code: 00-00 -> From VF mode (0) to SLV mode (1)
Main Frequency Source Selection -> Code: 00-05 -> From Keypad (0) to Potentiometer on Keypad (1)
Frequency Upper Limit -> Code: 00-12 -> Set to 60.00Hz
Frequency Lower Limit -> Code: 00-13 -> Set to 10.00Hz
Acceleration Time -> Code: 00-14 -> Set to 5 seconds
Deceleration Time -> Code: 00-15 -> Set to 5 seconds
Carrier Frequency -> Code: 11-01 -> From 5 to 16 kHz
Carrier Mode Selection -> Code: 11-02 -> From Mode1, 2-Phase PWM modulation (1) to Mode0 3-Phase PWM modulation (0)
