- Jan 7, 2016
- 3,279
After collecting all my electrical parts I was finally able to get my (new to me) Sharp knee mill running today. It was a bit of a process with the wiring and the programming of the VFD, which is a Lapond brand. https://www.amazon.com/dp/B075M8R77M?ref=ppx_yo2ov_dt_b_product_details&th=1
The issue is there is a buzzing noise emanating from the motor. It is about the same frequency as my tinnitus, so I had to have my daughter come and take a listen. Yep, it is there. One of the parameters that I changed in the VFD was the "carrier frequency" from 12kHz to 16khz, which helped ever so slightly, but not enough. If I lower that number below 10kHz the buzzing becomes prominent.
Would anyone have any thoughts on what else could be causing that, or is this just the way it is? The motor on this mill is a 230v, 3ph, 8A, 1720rpm flavor, and the original motor I might add, which I would like for it to stay that way. I am considering purchasing a different VFD but not sure if that would make any difference. Would love to get a Durapulse from Automation Direct but it seems that they are perpetually out of stock. I am considering a Teco or a Hitachi, but maybe that would not make any difference other than I could then say I have a "name brand."
