- May 7, 2013
- 216
I saw this diagram for a single-plate clutch and am building it. From the diagram it looks like the withdrawal sleeve is part of the pressure plate. How then is the clutch fork mounted so that it doesn't rotate? If the sleeve is separate from the plate how does it act to retract the plate? I'm thinking I might need some kind of thrust bearing as well?
Any ideas?
What you are looking at is a pull clutch, instead of pushing on the fingers you pull. This is same as in the 90's Corvettes with LT1 due to the lack of room to put the slave cyl. On this system the Throwout bearing or thrust bearing is on the inside of the pressure plate not the best idea but it works. They are a lot of fun to change I did mine the beginning of last year in a 92.
Todd
