- Apr 29, 2019
- 2,060
I believe everything but the head is made of .020 thick 321 stainless. It is all welded by hand, and to look at this welding close up it is of amazing quality. I originally thought it was robot welded, if you look really close you can tell it is hand welded. The head is machined out of a solid block of aluminum. the heat is not supposed to get that close to the front and there are some internal baffles to keep the heat to the rear, and the incoming fuel is sprayed on the back of the head for further cooling.
All of the hot section parts on my RC turbines are made of Inconel because they have to be really strong to hold together at 1500°F while spinning at 125,000+ RPM (not a typo) some of them will cruise at 250,000 RPM. Heck Idle is 37,000 RPM
