- Mar 19, 2014
- 2,681
Your pictures show you maybe used the old 4 flute tap style? That style of tap does not do a very good job of dealing with the chips it makes. And so can bind up with chips very easily and break. The gun tap is my tap of choice. As it cuts the threads the chips are directed to the front of the tap. No real need to cut CW and then back off CCW like you would with the old style. You can just feed the tap in all the way with no fear of chip build up and use cutting fluid where applicable, Also, maybe the gun tap is a little stronger because of its two flute design…Good Luck
