- Jun 22, 2023
- 379
i'm assuming that the steel lead screw would wear better than the cast iron. i'm planning on building the mount to adapt this to my mx-600A lathe so if the cast iron threads is not a huge drawback i can always mod it latter if and when it becomes an issue.I agree it looks like brass in the photo on Amazon. Wear? The softer usually material wears out first. Would you rather the lead screw or the nut wear out first and need to be replaced? I also wondered about oiled (impregnated) bronze, as used for sleeve bearings/bushing. Would this be better than brass?
Likewise, if you had a cast iron vs brass gib against a steel way which surface would you prefer to wear out. Getting a new gib is certainly easier than resurfacing a way. Also, if the gib wears evenly you can just tighten it up... at least for a while.
thanks to all for the input.
