- Apr 21, 2015
- 894
Not something I have ever heard, and if it's a violation to have one in a large, walk-in closet (pictured in the POTD thread) then I'll risk it. Too much utility in having it, no point in not.
I mean if it can't reliably detect 240v 30 or 50 amp current when in contact with the wire insulation, then what good are they for anything at all?
Every breaker should have a number. Every outlet should be labeled with the number of the breaker controlling it. The label can be behind the cover in a residence. It's also useful to make a map and put it in the panel.The old kitchen had a separate circuit for EVERY outlet, and another for lights. Major overkill, and made it difficult to do any electrical work, like replacing an outlet or switch, because every time you thought that breaker was off it wasn't yet.
I know for sure it's against code here, because it's a common request from my customers who want to add an outlet in a closet, the electricians quickly point out that it cannot be done legally. A washer dryer installed on dedicated circuits would be okay as those don't count as general use outlets, also closet could become a "laundry" when the job is filed. That being said, most of those installations are probably done illegally.In fact, many apartment laundry units in closets would be against code then, among other examples I can think of having seen over the years, including when I worked in construction. I'm betting that's just a myth.
I imagine the reasoning is, closets sometimes get crammed full of stuff and some electrical device plugged in there could easily get buried and overheat.... Also, the codes were probably implemented long before the wave of rechargeable devices, thus no reasonable need for an outlet in a closet was envisioned.Not something I have ever heard, and if it's a violation to have one in a large, walk-in closet (pictured in the POTD thread) then I'll risk it. Too much utility in having it, no point in not.
Ha Ha, been there done that... Seriously, those no contact testers are junk, if you are going to do electrical work get a proper solenoid tester, sometimes you don't get a second chance.You can do that with your bare hands!
