- Feb 19, 2014
Hi all, I have to drill/bore six two inch holes in 1/4" plate at a 22 degree angle. I am planning on clocking my brideport head at 22 degrees but I am not sure what method I should use for the holes. I was thinking of using a hole saw and going super slow with the lowest RPM it'll cut with my coolant mister blasting it...orrrrrrr do I drill a hole using the biggest drill I have which is probably 1" and then use a boring head to open it up the rest of the way? Please forgive my newbness. What would all you experienced guys do? Thank you.
