I use black and blue Sharpies on parts I'm milling to keep tabs on dimensions, hole location, etc. Works great for that purpose, but usually after handling a few times, there's more on my hands than on the part. For this application, it needs to be more permanent than that.Wide tip Sharpie??....................
Yep. Best way for sure, but a little over the top for this application. Paint is sounding better and better.Probably more involved than you want to get but nothing is as bulletproof as powder coat.
I tend to agree the optimal choice is powder coating. Now it comes down to the issue of sufficiency: Is powder coating overkill? Or, conversely, is paint inadequate? I have a headache.As mentioned before there are 3 types of anodizing and 2 classes commonly. What's happening is the outer layer (we're talking .0001-.003) is being converted to an aluminum oxide crystalline structure. Most home anodizing solutions are decorative and provide good elemental resistance without surface distortion. Hard anodizing is a little more involved and require a means to control the solution temperature and a few other variables; it usually has a color phase from dull grey (thinnest layer) to gold to brown to black (thickest) and a somewhat flat or rough finish.
For your application powder coat is probably the more user friendly surface finish and with the introduction of polymer suspended ceramaics provide a durable hard finish with minimal dimensional change.
All these processes are not as simple as getting out the rattle can. I on average powder coat between 21 to 60 pieces a week so it works out for me, but it is a PIA because there are factors like the weather, humidity and wind that complicate whether I will even be able to do a run. But there’s no way I’d go through it for just one part.I tend to agree the optimal choice is powder coating. Now it comes down to the issue of sufficiency: Is powder coating overkill? Or, conversely, is paint inadequate? I have a headache.
