What is the best, inexpensive bulk cutting fluid you can buy. Don't care if you have to mix it or not, just want a good reasonable priced fluid that can be had in 1-5 gallon quantity.
the box stores carry -Rigid brand Dark Cutting Fluid it's smelly but works very well and is relatively inexpensive. it's great for machining iron bearing materials
Rapid Tap & WD40 will work for aluminum
Started out using pipe threading oil from the plumbing department. Been using the Mobil cutting oil from Enco and seems to be working fine. I still use kerosene for aluminum and keep a jar of old bacon grease that works well on some materials.
Kerosene for everything except tapping where I use used motor oil. Motor oil can be a health risk, so I only use it where it won't smoke/vaporize and I don't let it sit on my hands for long periods.
I picked up a pint of Oatey dark cutting/threading oil at Lowe's last week. I've used it for turning, threading and milling so far and I really like it. It's cheaper than Tap Magic Pro tapping fluid and works great for everything.
Roy
