Have a question about bending L brackets.
I have some 1/8" x 1 1/2" HR flat bar stock that is too flimsy for the brackets I have to bend up at 90 Deg. The shelf brackets are going to be about 10" x 10" Max. (L shape)
Two brackets need not hold more than 150 lbs. total. Should I go with HR 1/4" thickness or go with Cold rolled 1/4" thickness. Also should heat be applied to either? Thanks, Al
