- Dec 3, 2013
- 1,844
... I have the balls and the surface grinder if I want one or more at some point.
I don't know if it's what you have in mind, but I've seen a couple variations on this theme:
If you can find a large nut to hold a 3/4" or 1" SS bearing ball. I imagine nuts in this range are fairly expensive. Good idea. I've seen it posted here by someone.
I've used a flatted ball (with sandblasted flat surface against the workpiece) and a short length of suitably sized steel pipe (against the vise jaw). You can cut the chunk of pipe pretty short. As long as it holds the surface of the ball off the vise jaw, it won't cause a dimple. I'd suppose you could add a small rare earth magnet inside the pipe to help hold the arrangement together while closing the vise (making it a bit less fussy). It's not a perfect solution, and Bob does raise a couple more valid points. But the pipe-and-ball method is also quick and easy, and will accommodate larger part variations than squishable wire will.Many of those "solutions" take up way too much lengthwise space in the vise and are fussy to install at the same time as the part.
Great idea, John! I like it, and will try it.I've used a flatted ball (with sandblasted flat surface against the workpiece) and a short length of suitably sized steel pipe (against the vise jaw).
