Mikey, I believe the method You describe pretty much is the standard method for squaring stock in the mill, at least its exactly the way I was thought to do it long time ago...
Erik
That is a good video, Emilio. Tom is a no nonsense guy. Lays it out there like a master machinist to an apprentice, and I suppose that is what he is actually doing...Here ya go, as requested:
Has anyone tried using the ball bearing with the ground flat on it to hold rough saw stock in a vise?
I just read a machining tip where (it's also in a book), where you take a .750 or 1.00" bearing ball and grind a
flat on it. I've always used a piece of soft aluminum wire. Other's use wood, cylinders of brass, etc...
I'd like to try this. Of course, I would use a piece of brass to protect the flat against the vise jaw.
Many of those "solutions" take up way too much lengthwise space in the vise and are fussy to install at the same time as the part. What we are most often trying to do is compensate for a small amount of out of square or rough condition in the work. We also want to retain as much friction from the vise jaws to the part as possible, that is how vises work. That is why something quick and dirty like a piece of aluminum welding rod or soft copper wire works so well.I don't know if it's what you have in mind, but I've seen a couple variations on this theme:
