I took some pictures. The one good fluted barrel I did on my friends Enco mill. I set the cutter in a flute but the picture quality is poor. One of the barrels shows what happens when you dont lock down the knee. That barrel shot ok but it sure looked crappy. I never used it in a match when there were some good gunsmiths there .Earl could post some pictures of your finished results?
Are you using a cnc machine or a manual mill? 5 inches a minute equates to 3 minutes per flute. I usually do 6 15 inch flutes, 95-100 thou deep to loose the 5 ounces I need. I don't claim to be fast. It takes me in excess of 2 hours to completely set up, flute, and clean up. At 5 inches per minute, a half hour set up time, and 10 minutes clean up, I would be drinking beer within an hour. When I try to go faster than about 2 inches per minute on the big mill, the cutter jams. I have a couple of brand new 3/16 cutters and some old barrels. I am going to see just how fast I can go with one of them. I will use flood cooling with Rustlick 255. I will let you know how I make out.I go full depth,(.100") in a single pass, but I had a brain fart on the rpm......it is 100 rpm, not 300. 5 inches per minute requires a sharp cutter.
You cant get much more rigid than that. your using about a 3 1/2 inch cutter with 24 teeth. Mine was a 2 1/2 with 14 teeth. your 100 rpm is close to the same SFM as my "couple hundred" Thanks for the correction. You saved me from burning up one of my new cutters Do you support the back of the barrel? Previous experience without support in the back (angle plate) resulted in 20 -25 thou displacement of the barrel. You could actually hear it when you were cutting. I now have an angle with 3 adjustable pads that I can adjust to keep the barrel straight.You are right, Earl......I was confused. I musta been thinking about another job, or that was the number setting on the power feed, or I just had another brain fart....anyways, around 2-3 inches a minute is what my DRO says. My set up is pretty rigid, using hex nuts for an index, and clamping directly to the table.
I know it does not help the 12.5 lb, but I use an ice fishing sled to drag deer out.BUT all this talk about fluting the barrel has me thinking........ and that is always dangerous
While I do not have a heavy contour barrel I thought that I could start with the full .100 deep flute near the chamber end and have it get progressively less deep to where it finally runs out at about 8 - 10 inches from the Muzzle, to avoid getting the barrel to thin anywhere. This is on a Rem 700 SS 7mm Rem Mag with stock 28 inch barrel. It really could stand to loose some weight. at 12.5 lbs it gets heavy a mile back in the woods, and knowing it is a mile back out dragging a deer too. I have also thought of lopping 4-6 inches off the end of the barrel. I really do not need the full 3850 FPS speed.1V1
So do I, but no way my gun will be bouncing around in a sled. Gun is always carried, loaded and ready. Never know when it might be needed quick. We do have bear (Usually, not always, in hibernation by deer season), coyote and wolves that all love fresh meat and will follow a blood trail looking for lunch. I never had to shoot a predator in self defense, But I have gotten as close as the gun up, cross hairs settled and safety off staring down a wolf. So far yelling has always worked.I know it does not help the 12.5 lb, but I use an ice fishing sled to drag deer out.
