Anyone done barrel fluting on a small mill? I have a grizzly g0695 mill. I believe the size is 8 x 30. I have done a lot of barrels on my Buddy's Enco mill (Bridgeport Clone) with no problems. My junior mill has a 1.5 hp motor and I am having trouble using a quarter inch cutter (2 1/2 inch) at a hundred thou depth of cut. Using a 3/16 cutter, I can cut a 15.75 inch flute in under 15 minutes. (175 rpm) I gave up on the quarter inch cutter after about 15 minutes and only had about a 5 inch cut. (175 - 235 rpm). Had to go very slow or the cutter would jam.
What are your experiences with fluting on less than a full sized Mill?
