- May 16, 2016
- 1,697
I'm assuming you are thinking of the cordless variety like makita or milwaukee and others make. Yes they work, but ae4 inclined to be underpowered, for anything but the light set of work. I did consider them before I bought my HAfco 5 x 5
One sales guy was very honest and basically talked me out of buying one. I had narrowed it down to Makita, for various reasons that suited me. I'm not saying one is better than the other because I haven't tried them all.
Anyway the sales guy said they were really only intended for use on construction sits for cutting steel frame sections that are made from rolled and folded sheet steel sections as used in steel framed housing for domestic use. For that they work quite well, and certainly better than a hacksaw. he loaned me a demo model they had for a few hours, I bought it home and tried it out on some bar stock I had just flat and round MS. Yes it cut it but was slow. It convinced me to buy a proper band saw, and I haven't looked back.
Blade breakage is very much how you use it. If you allow it to twist the blade while cutting yes the will break. Also the problem with blades is cost if you have to buy the proprietary brand blades.However if you have someone near you that makes bandsaw blades it should be much cheaper. This more or less true with any type of bandsaw.
However if your use is more like the house builders then have a good look and make a choice.
