- Apr 23, 2018
- 6,557
I see no need to anneal after soldering. It's a totally different application of heat compared to welding. When you use a torch, the anneal is sort of built in to the process. Welding is more like focusing sunlight with a magnifying glass, it affects a narrow part of the metal and cools quickly, leaving hardened zones. The torch puts more heat into a large, diffuse area and the work cools slowly in the air so it is more uniform and soft.
