I just came across a full roll that the vertical will take . Small blade 4 pitch for wood or thick aluminum maybe . I have a jig made up and can silver solder here also . Of course I just bought new blades for it last month . .New old stock blade coils can be a bargain compared to made to order blades...
Interesting, been going to TRY big welding a blade. Have been silver soldering them for some time. They usually work, occasionally they break. Interestingly from another forum, I was told you HAVE to anneal after soldering. Tried it, they broke every time, guessing the anneal weakened the silver solder joint?
Greg
It's a relief that I was able to uncoil the spiteful bastards without injury to myself or others!
I resemble this !The only problem being that you actually have to have some open floor space in the shop for this to work.......
I have some welding gauntlet-type gloves (ironic, given my above post ) that I put on, plus safety glasses, and I hold the coil away from my body and go slowly.I know what you mean, they can be like handling a basket of snakes.
One trick I learned, and I forget where, was to gentle toss the coiled blade onto the floor (tooth side up) and it usually springs open without injury or damage.
Brian
I thought it was anneal after weld. I have silver soldered my blades, and not annealed (for wood).Interesting, been going to TRY big welding a blade. Have been silver soldering them for some time. They usually work, occasionally they break. Interestingly from another forum, I was told you HAVE to anneal after soldering. Tried it, they broke every time, guessing the anneal weakened the silver solder joint?
Greg
