I just picked up a Delta 28-110 10" bandsaw. Made in 1957
and in sweet condition. Labeled as Homecraft.
Due to its good bones, compact size, and that I want to keep metal out of my woodshop, this ones home will be the metal shop. It is currently powered by a 1/3 hp 1750 rpm motor with a 2.5" pulley, pushing a 5" pulley on the saw. Way quick, and even if I reversed the ratio still too
quick. I have some 3phase motors available and an extra vfd, but not sure if I would lose too much torque lowering the hz as much as I might need to.
Another option is to pick up a 3 ph .4kw 1:20 geared motor on Ebay and run that with a vfd (variable speed).
What rpm range should I be targeting for the saw shaft for steel, brass, bronze, etc?
Thanks for any constructive advise.
