- Dec 25, 2011
- 10,513
The original spindle belt for the B and C model mills was 5L280, which is 5/8" wide at the top. If the cheap link belt runs low in the pulley, it is because it is too small, not because the pulley is worn out.
Given that the spindle was removed from the mill, there is no excuse for using a link belt. The only valid excuse for using a link belt instead of a proper size V-belt would be if the mill was in a mission critical operation and the primary requirement was to return the mill to operation in the minimum amount of time.
