- Dec 1, 2021
- 151
I've seen those...with the grooves cut...but they were out of my price range. Yep...that's about how broke I am...but still smiling.hmm, in that case I would suggest cutting (somehow) oil distribution grooves in each bearing to allow oil to get to the whole surface. It's going to be tricky as those types of bearings are more commonly stationary (think spindle bearings) with provision for an oiler or oiling system. Oilite or sintered bronze bushings are better for this kind of application with intermittent oiling.
Right now I just have the Unimat...Fraulein Turner as I like to call her...and a mill. Put new spindle bearings in her and mounting her to the granite really helped removing a lot of the vibration.
Don't think I want to try cutting the grooves with what I got as far as work holding and tooling. For now I just got to get by with what I've got....when that SS check comes in it's almost gone the same day. Got enough for food...and it's just me so it ain't so bad. A lot of people got it A LOT worse than me. Still paying on the house....but all my tools are paid for : )
If I oil them before I run it that day it should be fine. I can check the temp of the shaft with a gun while it's running and if it's heating up too much I just have to pull it apart again. With my present $$$ flow I'll be lucky to have it running by fall. Of course....when my NESARA checks start coming in I'll be able to afford new socks and underwear : )
Crap.....lol....the more I think about it....I think I will have to cut a groove in them. Maybe just a straight groove...width wise and a hole thru the middle of the groove. That would probably be fine for the gear bushing...but for the pulley bushings it would need to be a spiral I guess. With the oil hole in the pulley being in the center space between the 2 bushings...a straight groove might not pull enough oil in.
What do you think?
Hey...thanks again for your input !!!
