- Jan 28, 2011
- 3,485
I appears that your chucks may have what is called bell mouthed. They are tapered with the open end to the outside. Your work piece is moving around on the first one.
Yes even a pita beatter should still give you a decent finish. Try re running the piece but use the hand wheel to feed instead of the leadscrew. Just curious.
I would suggest resetting the preload on the spindle bearings. There was a posting about it here just recently.
Pierre
Pierre
