Atlas 10F V42
Milling an old boring bar that was scrounged out of the bin, so it can be used in this lathe.
  • VID_20190201_132157.mp4
    25.9 MB
Apologies, that was supposed to be a photo. And only one, delete one or both as necessary. Thought the upload had failed, takes a little time to load.
Nice work on the old Atlas. If you haven't done your thread repair yet, Loctite makes an epoxy repair kit with a release agent that would allow you to use your original fasteners. Mike
I deleted one of the two MP4's as they had the same file names and appeared to be the same file.
Will have to have a look for that, might be just the ticket.
Catch can finished.
Oil reclamation plant.
Fancy names for recycled junk.IMG_20180906_113005.jpgIMG_20180906_114737.jpgIMG_20180906_125851.jpgIMG_20180906_125905.jpgIMG_20180906_130029.jpgIMG_20180906_130128.jpg
New screw jacks. After putting risers under the bed feet, it was a little on the high side.IMG_20190216_203247.jpgIMG_20190218_114328.jpgIMG_20190222_190034.jpgIMG_20190222_190125.jpgIMG_20190301_150030.jpg
