- Feb 7, 2013
- 2,489
You could make a slurry with JB weld and cast iron dust and fill with that. An aluminum plate has some merit as
well and if thick enough one could mill some slots for mounting stuff. It all depends on if it bothers you.
It will be just as functional if you use it as is.
Just live with it, you'll get used to it and you know you're not the one that did the damage. You'll be using proper methods and the damage won't impair you. If it makes you feel better the JB weld or such will be fine.
