I use a dental drill every day, I think it will work. Don't force it, let it do it's job. You will need air and air control unless you go with an electric handpiece set up, but this tends to be expensive. If you remember going to the dentist he or she uses a footbrake that is on the floor below the chair to turn the air on and off, it is said to be all or non, on and off but this is not truly factual. The hose connections are very small and go on to barbed connectors.
Beware some of the very cheap handpieces having poor bearings and at that speed they chatter and can easily brake off the bur, under load. Wear safety glasses.
Good Luck
Good Luck
