- Nov 25, 2015
- 8,303
I have a lathe, mill, and surface grinder down there.
When using oil I have an exhaust fan that I put by a window in my other shop, I piped some 4" pvc up in the 1st floor joists, and turn it on when needed, it's a bathroom exhaust fan that I modified to fit in the window and connect to the pvc. It really helps keep the smell down, my wife hates it.. and before I installed it I had her wrath. Now not as much. I use a mister more on the mill, less so on the lathe, but I do have one, same with the surface grinder.
I made ramps that go up the stairs and use a harbor freight 120v winch at the top to raise and lower things on a dolly with big 5" wheels. It helps with some of the castings. I originally was carrying stuff down, but the surface grinder castings were way more than I could handle.
Sometimes I wear sneakers, but they are soft and pick up more swarf. I now mostly wear my ARIAT boots with flat bottoms, they seem to pick up less swarf.. I think the harder surface makes it less prone to minor chip infiltration. I also keep a good door mat at the shop entrance so I can wipe.
it's the bristle type.
Being downstairs is way more comfortable in the heat and cold... but on those nice days, I would love to be in the garage with the doors open... But you have to pick, and the machines like the basement better too, way less rust.. Actually hardly any.
