yes, i still use mandrels.
the mandrels i have go from smallest of 1/4" ,5/16,3/8,7/16,1/2,9/16,5/8,11/16,3/4,7/8,1"largest
mine are very slightly tapered about .003" per length for the set. the 1" seems to have a slightly steeper taper,i didn't measure it
they range in length from 3 1/2" for 1/4" to about 8" for the 1"
i bought them couple years ago used for a song at a flea market cheap.
a couple blemishes, nothing steel wool and a little get'ner done couldn't solve.
pullies in aluminum are easily turned and can be made quite sturdy if you resist the urge to make them too thin or narrow.
they wear quicker than steel pullies, but sure can get you goin' when the SHTF... all you have is some 3" 6160 and an hour to get a machine running before the start loosing tens of thousands of dollars in spoilage.
last part was a true story, i'll leave the company nameless, operating a chicken production facility... a packaging machine had a timed outfeed operated by stainless steel timing pullies. the timing belt broke their production stopped, they didn't have a spare belt, i didn't have an OEM belt for the unit and was told when contacting the manufacturer that the belt was half the country away and couldn't even be shipped until the following morning.
Needless to say i got the Emergency phone call to go bail them out.
the call description reported a broken belt, not normally an emergency and rather unusual for this customer to call with a call of this nature:thinking:. it was at that point, i knew i was walking into some trouble...
i was able to quickly find out there was no timing belt to be had locally, but they stressed that the unit must run a quickly as possible to avoid loss of fresh product.
upon inspection of the machine, a failed bearing was the culprit of our belt problem.
the bearing was easy enough to change out with the factory issued tools, but we had no belts.
luckily the production was not going to be start and stop.
they were planning a continuous production until all the product was packed.
the normal belts are toothed and flat and ride on toothed timing pullies.
the shop was equipped with a lathe, they also had all kinds of materials as well.
i spoke to the shop foreman and asked if i could use their shop to fix the packaging machine.
he gave me permission to use whatever they had on hand to get them out of their pickle.
i was able to cut 2 3" OD aluminum v belt pullies, turn them on centers on their Clausing lathe, and replace their 4" timing pullies.
i used their bushings and broaches to finish the bore to 7/8".
i used an A48 belt over tightened slightly to eliminate any slippage .
i got them operational in an hour and a half, but had to return and remove my fix to install the OEM parts 2 days later.
