- Jun 12, 2014
- 4,817
I would suggest you consider something like the Igaging Absolute Digital calipers, I have had mine for over 10 years and it is very accurate and always maintains zero. It does inch, metric and fractions which can be handy sometimes. Batteries typically last 1-2 years, and I always keep a few spares around and typically the display gets weaker when the batteries are going but it still works. They also have a fixture for using it as a depth gauge. At $45-50, best set of calipers I have used and compares to my Mitutoyo which I have in a larger size. My vision is also starting to go so having clear digital display is preferable over a dial in this application.
Electronic Caliper ABSOLUTE ORIGIN 6'' Digital Dept
iGaging's Origin Digital Caliper uses SUPER HIGH ACCURACY ABSOLUTE memory technology. It keeps track of its origin position once set. Whenever the digital caliper turned on, the easy-view large LCD displays the actual sensor position ready to start measur
www.igagingstore.com
